Hi there. Can anyone tell me how to stop the pullies from moving when i'm tightning the crank shaft pulley bolt, bearing in mind it's an automatic. cheers
Either remove the starter motor and jam a large screwdirver against the ring gear on the flywheel, or screw two bolts into the threaded holes in the pulley and wedge a bar across them to hold the pulley while tightening the centre bolt.
