If you are still looking, I was talking to the Romsey branch manager of Albert Jagger and they do have a contact for this type of fixing - give them a buzz, may proove worthwhile! 01794525870 or Wallsall 01922471000
Hi John,
Not got round to fitting the spots yet, still building up the courage to get the wiring loom fitted!
I'm still looking for rivets for you but where I thought we had loads they seem to be the wrong ones as we found out when you phoned & i looked in our stores, I'm still working on it though so I've not given up!!
Geoff W
Sunny Bristol
Cheers M8 I will ring them today ! thanx again for your support, this is like a giant jigsaw puzzle but we need the glue to put it together !!!
I should have stuck to the airfix kits !
May be out of their ken, but you could try Bapp Bolts at Barugh Green
or Sheffield Nut & Bolt.
Matt I can't believe the amount of times I pass that place !! Thanx for the reminder I think I may have to nip down there this dinner time ,their website is still under construction !!
Hi John,
Geoff W
Sunny Bristol
The Blue Angel eye spots are on and wired !!!! I put the lamps on and EMP at Barnsley did the wiring (I chickened out on diy) I have to say Roughtrax do exactly what they say on the tin !
If you ever want any metal sand/bead blasting, the corner unit up from EMP
on the same side is a very good place to go. Metal Magic, I think it's called.
They get all my quirky bits. (Vince..........., STOP IT............). They did
the viscous fan before I sprayed it.
Yes John, It's a Mk8 with a Merlin, next to it is a prop for a Griffon (as it has 5 blades) there is also, If you look hard, the Mk14 rebuild!
What colour did you say you were?
Just to help things along a bit colour wise......................
