Heated rear window
  • Heated rear window
    Now that its frosty Ive discovered my HRW doesnt work , the light comes on on the switch but nowt happens at the back.
    Any Ideas ?
    Steve
    Side mounts are the new top mounts !
    It's either a break in the wires where they pass through the flexy conduit by the left side hinge or one of the connections has come off the element on the glass. You'll need to remove the carpet and metal panel on the tailgate.
      What bushwacker says. see the last pic here, could be that (it was on mine):
      http://www.showmesome.info/hilux/workshop/rear_door.htm
      No longer a Surf owner.
        Thanks Guys will check later
