Dampers
  • Dampers
    Just a quick question can any of you guys that have done the L/Cruiser spring lift,i would like to know what shocks you have used for the 3" lift as i am in the proccess of ordering all my bits.The thing is will the standard shocks for a 2" lift be sufficient and not bottom out (so to speak) while off-roading as i will probably be taking off the A R Bar.
    If anyone has the +3" shocks could they possibably give me the number that is stamped on the shocks or if they have a code for them please so i can get them ordered from Barry.T.I.A
    Vince has said +2" are fine on the road, but he dosn't get his truck dirty so I don't know how much they limit flex at full droop.
    I just sold a set of +3" rears to The Fungus Guy, you want me get you a set?
      How much for the set of 4 + p&p please Tony
        Originally posted by stormforce1067
        How much for the set +p&p please Tony
        They are £35 each plus shipping (about £7ish I'd think, but Linda's filed the delivery note so I don't know for sure)
        Are you sure you need +3" for the front, are you getting that much lift on the front?
          Will the +2" be enough as i was thinking a bit ahead if i decided to get the front lifted the full 3" at a later date so i wouldnt have to spend out again on shocks
            i have the es3000's on and ditched the arb's rides great mate!
            TeaM BOFA4x4 Mac 2008
            www.bofa4x4.com
              have you got the 3" lift then Andy
                sure have mate, the full bush(whacker) lol
                www.bofa4x4.com
                  Downward travel on the axle is limited by the top control arm and fuel tank clearance on the drivers side anyway, see pic.
                    The only thing with +3" on a standard front is they might not collaspe enough. If you've jacked the torsions at all it might be OK.
                    are we talking 3000's or 9000's
                      thats ideal Andy thanks i was just wondering what they were like off road too
                        i have plus 2 fronts and plus 4 rears. its what they had on the shelp in the states mate, otherwise would have had plus 3 rears
                        www.bofa4x4.com
                          I will prob go for the 3000's as i am getting the L/C springs, the panhard kit and a diff lowering spacers too and tha brake hoses.I thought by lowering the diff then i may be able to crank the front a little bit more,what do you reacon Tony
                            let you know on the 18th nov, my next trip out!
                            www.bofa4x4.com
                              i do appologise for the niggly q's but i want to make sure i get everything right to start and not have to return parts that are no good
