What can I park my Surf on in garden?
  • What can I park my Surf on in garden?
    A bit of a random question, but does anyone know what/where I can get something to put on my garden to then park the surf on, i.e. some criss/cross matting or something like that? Just something cheap until I can get the drive properly sorted.
    I only have space for one car on my drive and I have two vehicles, so until I can get the driveway extended I have been parking the surf on my front garden. The garden slopes quite a bit down towards the house. Until recently no problem, but now its very wet outside the lawn is getting churned up. This means every time I go out the mud terrains leave a trail of mud down the road.
    No longer a Surf owner.
    how about some of those plastic pieces they put across holes in road ,pavement
      a couple of scaffold boards should do
        joker - not sure what you mean but do they have a name?
        stormforce - I don't think scaffold boards or whatever will have enough grip when wet - the garden slopes quite severely so I need grip to stop the surf ending up in my lounge!
        Been searching the web for something suitable and I have found this:
        http://www.polymax.co.uk/Catalogue%2...ymax-orbik.htm
        dunno how available/cheap it will be tho...
          sand tracks from the army surplus. cheap as.. that polywossname stuff can get a bit dear in small bits
          it's in me shed, mate.
            or why not just dig out a couple of shallow channel line with some plastic and put some gravel along it then you should have the grip and not cost too much as long as the ground is fairly solid
              dont know the name for them they are about 3ft by 2ft yellow or red (i think )
              the electricity co's use them to cover holes (when they dig lol) had acouple at work i think one of the bosses found them lol and used for ramps,
              you may find some by a hole near you
                This is the stuff I normally use for thing like emergency vehicle access through green areas.
                http://www.grasscrete.co.uk/
                  http://www.machinemart.co.uk/product.asp?p=051817010
                    Hi Codlord, bin there last year ( still ain't finished it yet, we're getting there) A Cheap solution....Went to Wilkinsons, bought some of that "thin" black sheeting that stops the weeds coming through, laid it down.
                    Then of to Wickes or similar for some bags of pea shingle & sprinkled just a thin layer to keep the sheeting in place & enable us to Park on, sorted !!!!
                    Hope this helps & good luck.
                    Oh I forgot, cut a few bricks into to the mud just like a seawall (to stop ya truck running away) & use ya truck as steam roller over the stones
                    Jesse
                    There's always a Payback.... One less problem when ya done it tho !!!!
                    Buncefield Burner
                      Thanks thats the kind of stuff I was searching for - actually searched the Machinemart website for a few keywords but did'nt find it. Think I will get some of that stuff, should only need 1 matt cut into 4.
                      Thanks for all the suggestions - I thought about some gravel but due to the slope I just think it would end up in a big pile near the house eventually.
                        do you know how much this stuff is a square meter
                          No idea on the materials. With all the labour, top soil and seeding, I'd say around 50 quid a square metre. But that's for someone to come and do it for you. Probably dirt cheap just for the materials though - it's pretty much concrete blocks just laid on the floor.
                            cheers sancho just an idea for a finish on our drive we are doing at the mo
