black smoke
  • black smoke
    Hi every body, can anyone tell me how to rid the dreaded black smoke. My garage door is covered, and it's a pain in the a$$e to get off. It has a stainless steel exhaust . Do you think this has anything to do with it. Cheers.
    try using some redex to give the fuel system a good clean thru and do the egr mod that may help aswell
    http://www.hiluxsurf.co.uk/forums/sh...hlight=egr+mod take a look here to see what to do
      exhaust being stainless steel won't make any difference. have you done the egr mod?
        Tried egr with the ballbearing and have been using redex but no change.
          try cleaning the turbo to throttle housing pipe thing, there sometimes is a build up of oil in here due to the rocker breather pipe depositing vapour over a long period of time. do this anyway, then put an oil catch can/seperator can in-line on the this breather to stop this in the future.
          are you losing/burning oil?
            park so the exhaust isn't facing the garage door.
              Add a bottle of 40 into the fuel tank twice a year, no more dirty injectors and no more MOT failures due to smoke. 40 aint cheap but dont waste yer money with any other cheapo cleaners FFS it's only every 6 months innit.
                When did you last change your air and fuel filters?
                  Nowt wrong with a bit of black ,smoke it keeps the tailgaters at bay. Much better than white smoke mate, far too expensive Try changing the filters ,or dont close the garage door
                  Spoggle
                    All diesels will leave black splodges (technical term) if the tailpipe is aimed at something from a few inches away, no matter how 'clean' the fuel system is.
                      This is spot on. If thats all it is and youre not belching out black smoke mile after mile it is not a problem, it is normal.
                      Park outside, that will cure it
                      Bogus
                      Сви можемо
