Hi my son wants me to ask on our surf, On ignition wire with the ignition off would there be any voltage showing on a multi meter, it would help to solve a problem with our poorly car at the moment!!!!thanks!!
help electric question!!!
It is not unusual to have low voltages showing at various points on any vehicle, the voltage is not "coming out" its just there.
What you need to be measuring is current flowing from the battery when it shouldn,t be and that's done by disconnecting your battery and connecting your meter (set on amps) between the battery terminal and the connector that you have just removed.
If you have twin batteries remove the earth terminal from the second battery before testing.
It's rare to find that the problem is leakage, the problem usually turns out to be faults in battery/charging system.Laugh!!! I nearly bought my own beer.
Paul
Originally posted by paulhIt is not unusual to have low voltages showing at various points on any vehicle, the voltage is not "coming out" its just there.
Where did you get your figure of .03 amps from?
That current is probably being drawn by things such as the radio memory and the ecu, another .03 amps is not going to discharge your battery not for a very long time anyway.
How long is the battery lasting before going flat?
Are the batteries original or have you changed them?
I expect they are something like 70 ah batteries which, if you have two will give you 140ah, theoretically that will give you a drain of 1amp for 140 hours yet you are only draining .06 amps.Laugh!!! I nearly bought my own beer.
Paul
Originally posted by AuldNickI ate an elicritin once, you want to confuse fit a fuse. Bin all multitesters and get a bulb with wires on, that's how Bill Gates did it, nowt worse than a "spark" and a meter, it's doomed!
