Anyone no the offset off a standard 3rd gen alloy would check in the morning but leave for work while its still dark.
Offset On Standard 3rd Gen Alloys???
sorry its late and me vodka is starting to kick in sounding to be a wee bit to complicated for me sorry i couldent helpOriginally posted by soupersurfercheers mr surf, so if the offset on my new vigo alloys is 30 i need to space my wheels out around 22mm to get them the same???
Offset is normally -8mm, meaning the mounting face is 8mm behind the centerline of the wheel.
Anything with more positive offset will sit back into the wheel arch and may hit the springs, or wishbones or chassis on full lock. Can be cured with wheel spacers.
To much negative offset will foul the bumper and bulkhead on full lock and stick out from the wheel arch further. Can be cured with suspension/body lifts or angle grinder.
