Not long ago, the exhaust fell off where it crosses the rear axle.
As it just sat there on the rear axle and didn't make a different noise, I didn't really equate the new rakish angle of the tailpipe and the fact my cargo gets warmed nicely with a problem!
However, as I have an MOT later this month, I'd better see about getting it replaced.
Options :-
1) Have the bits welded back together in a sleeve to get through the MOT (my mate has offered to make a flash new one, but in his own time)
2) Fit a standard rear pipe
3) Get a full stainless system (I am keeping the truck a while)
Soooo...
a) Anyone got experience of stainless ones for the surf? Who did it? How much?
b) Where's cheapest place to get a replacement back section?
c) Should I sack my mate for being slow?
All this hassle! I have a bl00dy driveshaft boot to sort out too!
TONY?!?! Fancy doing the lot?
Options :-
Soooo...
cheapest/easiest option is just replace the rear section (or center section, it often rusts in front of the join, and the tail pipe is OK, you might want to check)
