Filtering and Using WVO straight into My Surf
  • Filtering and Using WVO straight into My Surf
    Afternoon Guys n Gals....
    I have just setup my Filtering system for WVO, Its basically sent through a 20 micron filter then a 5 micron filter.
    My Questions are as follows:
    Is it better to drain off the gunk @ the bottom of the settling barrel before pumping?
    Is it ok to dump WVO straight into the tank once its filtered?
    The WVO i am filtering is used for fish and chips only... what potential problems could i run into for this?
    Is anyone running on WVO??? If so what ratio are you using ?
    Any advice on this would be fantastic...
    Stu
    http://www.manicgamer.net
    Stu
    cats and drunks following you
      Are you drying the veg oil and getting rid of all the water?
      Here is a guys post on my other forum. His name is Bjorn and the information is courtesy of him. This is how he makes it.
      http://www.steelsoldiers.com/index.p...ewtopic&t=5140
      This artical is courtesy of Kenny on the same site. These guys are heavily into Bio production as it's legal to use in the States, and they don't charge tax on it like they do here.
      Hope this helps
      http://www.steelsoldiers.com/index.p...ewtopic&t=4510
