idle rpm
  • idle rpm
    hi all. just reading some tech data on another thread it says that a 3ltr td auto should idle at 800rpm.is this right because i have altered mine before to 800rpm and it seems to surg real bad when i select drive or reverse. so i put it back down to 6/650 where it was
    Does this mean that mine shouldn't be idling at 1000????
    Nihil illigitimi carborundum
      mine idles at about 750 and its not too bad
        Not sure about the autos as mine is a manual and it idles about 800 at cold start then drops to around 650 ish when warm. this seems fine as if i drop it lower it still idles ok but you get to an idle where it causes the truck to vibrate. if i up the idle to 750ish (when warm) the vibs fade.
        I think alot depends on the truck and you're better setting it at what is best for your truck.
        BEWARE OF THE REAPER
