Before the big trip i checked properly this time the transmission fluid and found it was about an inch above the hot mark with the engine cold, so i drained off an icecream tub full and it was then between the cool marks' it was also dark red verging on brown so i want to change it, been checking the threads and understand Duckhams Dextron111 is what i should get, question is how much does the box take from empty (drain plug on the box sump) ? does this drain all of it (from the cooler, if there is one)? also understand there is a magnetic filter that should be washed out, where is that located?, any other special things to do on a oil change Cheer's in anticipation, Ian
