Hey all!
I've been browsing this forum for a while now and I've also been shopping for a 1991 Hilux (they have to be 15years or older to import em into Canada). And I've been wondering; What needs to be done to these trucks to make them survive the Canadian Winters? I should mention that I live in Winnipeg, Manitoba where the temp regularly drops to -40C throughout the winter.
Now I realize that the oil will be the first thing to be changed. A block heater is a definite must. And the Batteries will need a good checking (do both need to be kept or is just one ok?)
-What about Glow Plugs... do they need to be more efficient ones put in for better starts?
-I'd like to possibly/eventually put in an intercooler, will it need to be removed during the winter? or does it matter at all?
-Are there all-in-one Remote door/alarm/start systems available that will work on the Hilux (1991) with a turbo timer?
-What about the High-Idle... Can it be set before or after shutdown (the night before) so that it will start and idle high the next morning (when you hit the remote start to avoid having to run outside)? or will that mess with the start settings?
So yeah, those are the first few questions I have for now. Any and all help will be greatly appreciated!
Thanks!
Thanks!
 )  It does have 2 batteries but even when it was only 5 or 10 below it would take several trys to start it and then for about 30 seconds it ran like SHAT!  Some solutions however for you who still want to drive yours all winter would be to put in some thinner oil, install a block heater and possibly invest in one of these nifty oil heaters I've been told about.  Apparently you can get magnetized ones that you just stick on the bottom of the oil pan!
 If I remember correctly, they seem to cope with it well enough. Can't remember seeing anyone say they had any real issues with the Toyota engines in those temps.
