Coil spring spacers
  • Coil spring spacers
    Where can i get coil spring spacers ???
    Can anyone supply the High molecular plastic ones ???
    You want to talk to Danno on here as he gets them made
    http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=20231
      Hello,
      Try this link http://www.4crawler.com/4Runner.shtml#top
      They sell pretty much everything, plus the site is a treasure trove of Surf info - soon you'll become a Surf bore................like me
        i got mine from 4crawler, if i remember correctlly it worked out at around £90 in total from the states, and they are the poly ones.
        dannos are alu.
        so its up to yourself, you will probably get them quicker from danno as mine took about a week and a half to come from the states,
        http://mysite.wanadoo-members.co.uk/.../wip/index.htm
        cheers scotty
          .....or maybe fit Landcruiser springs!
          I can supply you with a drop bracket for the panhard rod....ahem!
            So that great big piece is a drop bracket?! I take it you were thinking forward to people doing a 10" lift?
              No silly, only up to about six inches of suspension lift.
                Not judging by that brackets size against that wheel.
                  Aluminium ones are best!!!!
                  But then I'm biased! Anyway, what is the thing with plastic anyway? Ali does the same job!
                  I NEED TO OFFROAD!
                    And they can be polished!
                      Or anodised gold/purple/red/blue etc............
                      Cool, match your shock boots!
                      I NEED TO OFFROAD!
