Garage Doors
    Originally posted by scotty
    you may be better with these to bolt your frames up, just countersink the head of them flush so they dont foul your doors.
    http://www.screwfix.com/app/sfd/cat/...00056&ts=49061
    remember with those hook and band hinges, you point them in opposit directions,ie, the top one pointing up then hang your door, then hook the bottom one onto the band and screw into place pointing downwards.
    this means that the local scum cant lift the doors off.
    hope that makes sense
    cheers scotty
    Cheer's Scotty, yea i intend useing them, i've seen a pk of four 6" anchor studs so if i fix 8 on the double door side and 4-6 on the single should be strong enough, i can grind off excess stud after countersinking the nuts,
    I looked at quite a few of those hinges and none did what i wanted so im makeing some, i need them to fix to the edge of the frame (6x2") on a sort of "L" bracket, I'm fitting 5 hinges to the double side so i can reverse one so the door's cant be lifted off (should any scroat be strong enough)
    Cheers Ian
