Any use for?
  • Any use for?
    Having a bit of a clearout, so this list may keep growing.
    Does anyone have a use for some backup UPS's? Possibly to make an
    inverter for the vehicle. APC ones with no batteries, but can't be arsed
    to replace the batteries so will probably end up skipping if no-one wants
    them. They're taking up too much floor space.
    Do you mean the little brown vans?
      Does it come with a man with a clip board?
      i like it muddy!
          What you clearing out then Matt? got any pics so I know what you're on about?
            part or model numbers would do... its the replacement batteries that are relatively pricey depending on the model...
              hi MattF
              what batteries do they run? are they 12v 7ah units?
              BTW how are things, i got a big test for mine coming up.
                Backup power supplies for computer equipment. They are an inverter
                that runs from an integral 12V SLA battery. That's why I wondered if
                anyone might be wanting to do a bit of for-in-vehicle modifying.
                This gives a rough idea:
                http://www.pcworld.co.uk/martprd/sto...&category_oid=
                  Originally posted by john.sally
                  hi MattF
                  Been so long since I replaced a battery, I can't remember for definite,
                  but they would be somewhere around that AH.
                  Seems to be working okay at the moment. Put the fan back in yesterday
                  after adapting it for a tad more clearance.
                  How are you faring with the rad. Have you had it recored yet?
                    all the batteries i have robbed out of these things have been 12v 7ah.... runs a lamp for ages...
                    it's in me shed, mate.
                      Only got the generic model numbers off them for the moment. Nearly broke
                      a limb trying to get close enough to read the fronts. (As you can probably
                      tell, storage space is becoming something of a problem. )
                      1 x Back-UPS 650
                      2 x Back-UPS Pro 650
                      1 x Smart-UPS 1000
                      1 x Smart-UPS 1400
                      There may be a couple more 650's knocking about somewhere. Can vaguely remember stashing some more somewhere.
                        just about to try my last idea before getting it recored
                        1" lift in rear of bonnet
                        dissconnected tranny oil cooler out of rad so the kenlowe oil cooler is on its own now and not heating up the rad hopefully
                        going to the Avalanche weekend with caravan so will be the ultimate test, will keep you informed
                        ups 7 ah sealed batteries are usually the type in alarm panels and they are about £15.00 each if you get them from an alarm installer
                        we go tru them like water, money for old rope chage batteries every 3 years when servicing alarm panels
                          If you're going to make up spacers to lift the bonnet, don't go for any more tham 3/4 of an inch, or the bonnet will be in too much stress when it's shut.
                          It just does, OK?
                            well if i get the tape measure out i guess mine is about 3/4" actually i just put longer hinge bolts in and packed them out with large nuts and washers
                            if it works then i will do what a lot of others have done and put vents in the bonnet, just been aroud the village and its amazing how much heat comes out.
                            cheers for the warning
                            john
                              in them funny BROWN overalls
                              Enjoying Life after Cancer
                              Pops
