I have had a slow/sticking rear window after I oiled and greased everthing all OK for a couple of months. It has finally stopped so I took the motor/gearbox off. The motor turns OK but when pressure is applied to restrict the motor it still wirrs but does not turn. Is there some form of slipping clutch or do I have to change the whole motor gearbox.
Rear Window Motor Gear Box
Vince bushwhacker had a fix for that, glueing a couple of bits back together
http://www.yotasurf.co.uk/forums/att...2&d=1138031482
The glue failed on mine after two days so I drilled right through the nylon gear, the rubber wheel and the metal disc and put three nuts and bolts through.Originally posted by surfoffroadThank you got it off and took apart looked ok but parted rubber and metal disc glued back together and hey presto window now goes up and down again
. I read on the site someware that another Toyota motor gearbox will fit the Surf anybody knows what model and year
PeteIt's only a hobby!
I replaced mine at the weekend with a Toyota Space Cruiser motor assy. Cost me £20. I think nearly any Toyota elec. window motor will fit as long as it's from the nearside doors. My last one was from a Daihatsu or Isuzu. All Denso gear must be the same!You can take my 4x4 from me when you prize the keys from my cold, dead hand.
