anybody know about goldfish??????
    Originally posted by mikey2119
    Who'd 'av thot a couple of pets costing a couple o'quid each would be so complicated. Probably cheaper gettin a dog mate
    Even a woman isn't that complicated to look after!!
    you try being married to a Cornish woman then,then you'll know how complicated they can be......i only wrote this cause shes just gone out.
      Make sure she does'nt see it then
          Its all been said and good advise too!! Bowls should be banned along with
          giving away fish at fairgrounds and the like, I've got pond fish and tropicles
          (along with a free range terrapin in a pond in the liveing room) Theres only too large tropicle fish in a fairly large tank but they still need good water
          circulation to survive, Get em out of that bowl double quick and into a decent
          tank with air, Best of all though is to get advice before you buy and save fish or animals suffering.
            as already stated the bowl is lacking oxygen.
            I used to keep tropical fish [18", 24" and 36" tanks] with variety of fish [guppys, mollies, kissing gouramis, neon tetras, red-tailed shark, angel fish and siamese fighting fish]
            Oxygen
            Either use oxygenating plants or purchase a small pump, clear pipe and airstone. A reputable pet shop should be able to advise. This will also help to keep the water cleaner although from time-to-time you will have to change the water.
            Cleaning
            If like me you had several tanks you can purchase a cleaner that uses the pump to pull the water through a gauze so that the muck and algae is captured into the gauze and the water is returned cleaner.
            Periodically, I use to place the small pebbles into a pan and bring the water upto a simmer to
            1) Kill the bacteria
            2) You can see the scum on the top of the water.
            Water
            It is better if you can capture rain-water as this will be more Ph balanced than Tap water.
            Let the water captured come upto room temperature before changing some of the water - you dont have to change all of it unless your giving it a thorough clean.
            Adding New Fish
            Always keep the new fish in its water in the bag and place the bag into the tanks water before releasing the fish. This will allow the water in the bag to match that of the tank.
            Gaz
              [QUOTE=Gizmo]as already stated the bowl is lacking oxygen.
              Oxygen
              Cleaning
              Water
              Adding New Fish
              there's always one isn't there
              Is it supposed to sound like this??
                Where did the gravel come from and the tank??
                was it cleaned properly before you added water and fish??
                May be the fish are suffering because of properties in the gravel or on the tank. As my neighbour once found out that the tank he brought had been used for marine fish before he had it. To late, the remains of salt in the tank did his goldfish in.
                My 4x4
                My choice
                Back off
                  I have a choice of three fish I could lend you to solve the problem. A 12" Red Head cichlid, an 8" Xingu Pike cichlid, or a 10" Jaguar cichlid. Put one of them in the tank before you go to bed...
                  ... next morning the problem, and the goldfish, will be gone
                  • #24
                    nice idea but i dont think mi daughter will like it somehow....
                    CHEERS JOHN................
                    • #25
                      the gravel came from the local branch of pets at home, and the tank was an hand mi down from a family member. all the gravel and tank was cleaned out with boiling hot water and left to soak, but no cleaning chemicals were used.
                      • #26
                        Originally posted by charvell
                        Get yourself a nome with a fishing rod and some worms
                        already got the gnome and a rod just need some worms....anybody??
                        • #27
                          when youve got a women like mine you will do anything to keep her quiet!!
                          and i will deny all knowledge that i said this ssssshhhhhh
                          • #28
                            The first rule for any man in a marriage/relationship. Learn how
                            to be a complete coward quickly.
                            Matt
                            • #29
                              Matt
                              me a coward nooooo way the mrs said i can say that
                              • #30
                                [quote=mikey2119]
                                Oxygen
                                Cleaning
                                Water
                                Adding New Fish
                                And what is meant?
                                Gaz
