Rear Window
  • Rear Window
    Hi all after playing in the Salisbury mud the weekend I washed the truck with a jet wash. I also cleaned the engine bay as well as under neath. Now my rear window will not open/close from the internal switch, all is fine with the key in the back. So is there a fuse or relay in the engine area or is it possible a plug has come undone underneath ? cheers in advance John
    Check you haven't pressed the window lock button on the drivers door.
      Doh didn't even know that button was there Cheers Bushwhacker all ok now
