What grease for steering idler?
  • What grease for steering idler?
    I have bought a steering idler from Roughtrax and it has a grease nipple in the centre but no grease, I sort of thought it would come already greased up but evidently not...
    What grease should I use? (and where can I get it from?)
    Thanks.
    Any general purpose LM grease from a car spares shop will do.
        Okay, I bought the grease and gun.
        I attached the gun hose to the idler nipple and filled it with some grease but the air inside the idler just became compressed so I could only put a limited amount of grease into the idler.
        I unscrewed the nipple and some grease and a blast of air came out, so I tried again.
        Is this normal, are you supposed to fill the idler full of compressed air and a bit of grease or am I doing something stupid?
          There should be a vent point to let any excess grease escape. Air is bad - grease is good.
            I didn't see an air vent... could it be under the brass cap/top?
            This is a new unit, does the cap come off?
              Problem solved
              I prised the cap off last night, loosened the bolt underneath and tried again with the grease gun.
              It worked, grease was oozing out from every pore!
              Problem solved.
