Boo failed MOT
  • Boo failed MOT
    I hate MOT testers!
    Failed the '89 on a chunk missing off the side wall on a tyre, a sidelight bulb and a hole in the sill/floor pan joint. Oh and a smoke test.
    Best way of curing the smoke test anyone?
    Got three days to borrow a wheel and tyre. Needs to be a 31/10/15. Will put the old one back on after test. Its not that badly damaged.
    I NEED TO OFFROAD!
    Originally posted by Danno
    I hate MOT testers!
    Dan,
    Give it some veg, redex and drive it like you stole it !!!!!
    That should reduce your emissions m8
    Trev
      I'll sell ya a ball bearing for five quid!
        Careful !!!!!!!!!!!!!!!!!!!
        Danno comes armed with cable ties
        Trev
          Bugga! I got loads of them too!
            I hate MOT testers!
            Add some Veggi b4 you take if for run (so it's well warm) before taking it back ... Good Luck
            There's always a Payback.... You just can't see it Comin !!!!
            Buncefield Burner
              my surf was smokey, i read that atf would clean your injectors so to test i put 1 ltr in my diesel cit` bx and it ran ok with less smoke at mot time they only did i full throttle test and it passed on that,it helped that it had just been over the nat speed limit in 4th and i kept it running when i arrived.
              in the surf i filled the fuel filter with atf(mineral not synetheic) and started it up and as advised on the forum drove it like i stole it,switch off o/d on m/way next day it had less smoke still some but better
                I got a wheel and tyre you can borrow.
                  i stuck my rooster up there... but it was a bit big so i just used the beak....
                  the rest of it made a nice roast for tea!
