Hi all,
Sorry if this is in the wrong section, just i need to sort it out asap as i've left my girlfriend with the Surf (no that's not the problem!) and this is causing her loads of problems out on the road. It can be fine when you start it up, it's always ground a bit going into reverse, but after going for a while, or after stopping and starting again it just wont go into gear, sometimes it will go into 3rd and you can pull away slowly, but on a roundabout that's not much good. I just can't force it into gear,even with two hands, then the next morning, it's fine. Any help would be greatly appreciated,
Many thanks,
Nick.
Many thanks,
Nick.
