Raised breathers
  • Raised breathers
    Has any one fitted raised breathers for the diffs on there surf. Are they an off the shelf item ( if so where from ). or does anyone have info of how to construct them on a budget??????????????
    www.daemon4x4.org
    no I havent yet but its on my list of to do jobs - hopefully some top notch hosepipe will do the job!
    finally sorted my dodgy towbar wiring and fixed 3 sockets to rear bumper of the Surf to stop me ripping them off and water/mud getting in!
    Tim
      If you pull the cap off the original fitting, there is enough of a nipple left to get a hose over and jubilee clip it on.
        He He he your towbar must look better now then
        www.daemon4x4.org
          I would like to see a SURF with an outside breather pipe on it..??
          Anyone got any pics.??
          SLIPPERY WHEN WET.!!
            There is a thread where you can buy threaded tubes from toyota that fir where the existing diff breathers go. Then you pipe from the diff to the engine bay and cap of the pipe with the original diff cap........works well
              You won't see much, you just run the hose from the diff up to somewhere higher under the wheel arch or up the bulkhead. Put a small filter on the end or just a loop in the end to keep water out.
                Some pics.......
                  Some pics.......
                  Thanks all ... now to get some parts and start my project
                  www.daemon4x4.org
                    Some pics.......
                    they're the bits i've got, part number ties up with a corolla i think. got 2 in my glove box waiting to go on! got the number from an article in "petersens off road & 4wheeldrive"
                    Diesel, like petrol only better
