Interested??? Who wants one???
Am making them up from 3/4/5/6mm+ alloy
They will be similar to the pics I have posted.
It goes right under the x-member and under the front diff - I have left a drain hole for the diff drain plug. It uses the exsisting fixing holes that the plastic type fit to
If people want them with fancy holes in or extra water drain holes (for the waders amongst us!
It will be about £30 (depending on how thick you want it)
Mine is made from 2.8mm alloy and when it has been bent into shape is extremely strong.
