I've just fitted some new xenon headlight bulbs with a higher wattage than my standard bulbs, and have now had a problem with my battery.
Now, this may be a coincidence, but does anyone know whether a higher rated bulb could drain the battery to a point where it won't turn the engine?
The bulbs are 12V 100/90W which is almost double the wattage of the original ones, and when I switch them on, the battery indicator on the dash does drop a little bit. I can't say whether the indicator dropped anyway when the lights went on.
All I know is that the car wouldn't start last night, and when I replaced the battery, it started first time.
Do you think I should change the bulbs back and re-charge the battery, or is it a coincidence, and my battery is shot? Any thoughts?
Merry Xmas to all you fellow Surfers !! May the new year bring reduced Diesel prices and the s****ping of the alternative fuel tax.
