brake fluid?
  • brake fluid?
    ive been through the seach facility to find out what brakefluid to put in my 3rd gen and found two posts, one saying use dot 3 and one saying use dot 4?
    any ideas which is the correct one. also what grade engine oil do i use
    cheers
    I've been using Dot 4 brake fluid, and 15W40 semi-synthetic engine oil.
    Everythings been o.k.
      does it make a difference that your truck is a 2.4. cheers anyway
        No, just my preference. It'll be fine for your truck.
          Hi lux and 4Runner manual says DOT3
          http://www.hiluxsurf.co.uk/forums/showthread.php?t=62
          That link leads to servicing sticky
          Mostly secondG
            i didnt think you could get DOT3 anymore....
            Tim
              cheers
              A label on the brake reservoir of my 1997 3rd Gen says Dot 3. So as that is what has obviously been used by the previous Japanese owner, that's what I've stuck to.
              On the Dot 4 bottle it says that it is compatible with Dot 3 as well - so you pays your money and takes your choice!!
              As for engine oil, I always use Magnatec GTD.
              Keith
                cheers
                See attached:
