towing weight's
  • towing weight's
    what can a gen 3 surf tow legaly is it 3.5 tonnes
    steve
    www.floatingpontoonsolutions.co.uk
    steve
    nope.
      nope.
      Excellent
        There isn't much info around for 3rd gen Surfs, but the US 4Runner of the same year can tow 5000lb (2250kg-ish) But your's will be heavier due to the deisel motor, so may be a little higher.
          Originally posted by Andy W
          Excellent
          Factually correct, and concise.
            [QUOTE=TonyN]Factually correct, and concise.
            so how do i find out for sure?would i have to get in contact with the minstry of transport?do you think it would cope with 3.5 tonne's (if no one was watching)?it has a 3" lift kit fited
              my rule of thumb is, as long as it doesn't look wrong and your confident that it'll drive ok, then go for it!
              try toyota for the towing weights for a colorado of the same year... they're the same chassis and engine, just a bigger body on the LC... so that'll be your closest match
