An interesting digital camcorder tip
  • An interesting digital camcorder tip
    Hi,
    Got a digital camcorder ?
    Want to film your exploits offroad ?
    Do NOT want to glue a mounting on the dashboard ?
    Lacking someone to hold the camera ?
    Use Window's Movie Maker ?
    If you can answer with 5 yes's then I have the cure for you
    Get one of those sucker mounts for the camera, hang the upside down (if you camera is like mine then that means the little screen is on your side of the camera now ) and record away.
    When you edit the finished results check out the "video effects" available in the Movie Maker software - there are invertors.
    I needed to add both the vertical and horizontal inversion, but got my movie the way I wanted
    Trev
    Or a cheaper version. Do what I do and use copious amounts of blu-tak and stick it to your dash! It comes off the cam and dash no problem and leaves no marks! Did it with my old analogue brick camera and it never fell off.
    I NEED TO OFFROAD!
      Already got a sucker mount, also have a clamp mount, but it won't stretch to doing both uprights on a headrest
      Trev
