front bars from rough trax
  • front bars from rough trax
    hey got some 3" front bars from roughtrax,fantastic quality,
    got them on ,just finding it hard to attach the smaller support brackets the ones that bolt to the bar just in front of the rad,they seem quite secure at the mo with the just the bottom brackets and bolts and stuff ,has anyone else had probs with the fitting off these bars .any tips?
    hey just got a new 30 td surf all the gadgets 1997 metallic black niceeeeeeeeee
    I've got the same bar...i didnt bother fixing the small supports,too much hassle. I think the bar is designed to fit a hilux pick-up meaning the front would be easier to get at.I didnt use the brackets that came with it either as i couldnt seem to get the holes to line up.Instead,i used the original a bar mount,bolted at the front and welded at the back to make the bar sit at the right angle.a bit of a bodge....but its secure!
    So many toys-So little cash
