fuel injection pump renewal.
  • fuel injection pump renewal.
    hi guys,ive finaly managed to get hold of a fuel pump for my 2.4,i was going to attempt to change it myself,i have done a search in this forum and it doesnt seem to be to bad to do,but i have no experience with this pump so any advise would be greatly appreciated,do you need to reset the throttle control switch if so how?OR on the other hand should i leave it to some one with the specialist equipment to do the job.
    www.overfab.uk
    Maybe some helpful photos here......
    http://www.toyotasurf.asn.au/techsite/fuelpump.htm
      thats the pics ive been looking at,doesnt look to bad,but it doesnt say much about re-timing the pump.
      www.overfab.uk
        There should be some notches/marks on the pump and the engine casing to set the timing.
          Still waiting for my new one... i think the garage are trying to fob me off slightly after finding out how much they are to change.... (£1777+VAT anyone?!)
          Tim
            they need i paid £150 from nippon auto spares up in london.that included vat and carriage,when it got here ,the next day.it was all boxed up and well protected with bubble wrap and it looked like it was brand new.so a big thanx to nippon auto spares.
            www.overfab.uk
              Got a number for nippon auto spares? I need a 3.0 pump.
                There is a timing mark here - - along with a corresponding mark on housing. A mirror comes in handy for seeing these. The other timing marks are on pump sprocket and housing.
                  Hi
                  I could also do with a number for a breakers as the pump packed up on my K reg 2.4 auto.
                  thanks.
                    Nippon number 08000319918, they have a 2.4 pump for £150 at the mo`
                      There seems to be a lot of Toyota fuel pumps packing up on this forum. Are they designed on the Bosch fuel pump?
                      A fuel pump is a very reliable peice of kit, and should last the life of the engine, so why are all these fuel pumps breaking?? I would be interested to know if all you guys that have had a pump go on them have been running Veg oil in your trucks??
                        The surf pump is a nippondenso bosch copy.
                        I have a leak and have used a large percentage of svo in my surf, i`m going to try the millers seal kit first as a rebuild is between £750 and £1300.
                          Many thanks ssray, Ill give them a ring, only had trouble since I've been using bio diesel
                            Hi angry, it may be worth you getting some kind of heat exchanger plummed into your system, fuelcat etc, on the aussie site they are blaiming low sulpher diesel but not in your case.
