Pro Comp 9000
  • Pro Comp 9000
    Um
    dumb question follows :-
    I have the 2" lift kit from roughtrax and am doing the rears first got the n/s spring in got the n/s original shocks off about to fit the Procomp 9000's and am confused by the 2 bushes and 2 domed washers where should they go
    cheers
    Bobo
    It normally goes, shock-washer (dished up)-rubber-washer (dished down, small raised bit round center hole to locate in chassis)-chassis bracket-rubber-washer (dished down)-nut.
    Confused?
    As long as you get a washer top and bottem to cover the rubbers it'll probably be OK.
      Confused?
      dished up does that mean the washer in position looks like soup dish the right way up or is it the reverse
      cheers
      Bobo
        cheers
        Bobo
        Like a soup dish - you're looking for the washers to cup and support the bushes
        Roger
          Thank You for clarifying that for me I got the n/s rear finished after midnight!
          just going to start the o/s rear
          cheers Bobo
            Here we go again! dunno must be me or something read up on doing the front shocks peice of cake I think
            so took the n/s one off easy peasy
            will the new one go back in of course not!
            help and advice please
            could it be the torsion bars ? how can I tell ?
            cheers Bobo
              Whats playing up? Top or bottem? you never said in that rant.......
                yeah pardon the rant!
                basicly the new shock is too long i.e when I tried to put it in position the bottom eye is over 1" below the lower bracket can It be compressed if so how
                cheers
                Bobo
