Not Surf related but any help appreciated
  • Not Surf related but any help appreciated
    VW Golf GL 1992
    Hi Guy's, I need your expert advice. I started my girlfriends car this morning and it was fine, later on I just started and move it maybe 1/2 metro to open the boot, now the car does not start anymore, starter motor running fine , battery fine but looks like when the petrol reaches the engine, engine cuts down, any ideas on it?
    I will appreciate any help please.
    Regards
    John
    is there fuel, spark, air??
      Yes there's fuel and spark.
        is it firing at all?? or just turning over and over?
        any strange noises?
          any strange noises?
          I's firing and I was told the starting module failed????????
          Do you know what that's mean and how can I reset it?
          TKS
            is it the ECU??... try disconnecting the battery for 15-20 mins to reset, but it could have burned out. so will need replacing.
              If everything is there the timing could be out??? Check the camshaft, crank sensor etc then
                Thanks for all your help Guy's.
                In the end was only a loose connection on ignition barrel.
                Regards and thanks for the help
                John Neto
