I spent two weeks camping in cornwall and used the back of the surf as a dumping ground for all the stuff we did'nt want to be kicking round the tent.
However using the back window all the time took its toll on the battery. We didn't drive anywhere one day but still used the back of the car via the rear window. The following day the battery only just had enough power to start with a struggle.
Questions....
If I fitted another battery could one be used just to start the truck and the other be switched on while the engine was not running.
On a yatch they have a dial that allows you to use the one battery just for running the lights and bits at night then you switch to the other for starting.
Can it be done??and how? what do you do? how does the charging all work?
I only have a single battery
Mark
Questions....
Mark
