I Car`nt belive it but i`ll start at the beginning.
Last Sunday,set off to Brighouse Bay in Dumfriese & Galloway with surf and caravan, a trip of some 177 miles.The trip up was perfect, average about 60/65mph,only really travel at that speed so the overdrive does`nt keep going on and off.Flew over Shap summit like it was`nt there, fuel , 19 mpg,not so bad at all.
Now i constantly look at the temp gauge.As i sit in the drivers seat looking at the temp gauge,when at normal running temps, you can always see a line of black between the right hand side of the orange temp needle, and the left hand side of the temp symbol,it`s like this wether towing or not.I was beginning to think the gauge was faulty it was so steady---until the journey home that is!!!
Travel back down the A75 towards the 74 no probs,then the M6, so far so good.
Whilst climbing shap summit the speed droped and off came the overdrive,so i backed of the pedal abit, revs about 2500/2700.About 3 minutes after that i smelt it.You know that hot steamy damp smell that you know is not right.Quick glance at the gauge,touching the red
BO!!OCKS, i don`t beleive it!,i said as i threw out the cups off the holder and turned the heater and fan up to full.This did have an immediate affect, temp came down to about two thirds.
Limped on then the AT Temp light came on.Double
So now i`m going to have change the transmission fluid since i`ll have probably cooked that,and i`ll flush the radiator out and refill with a bit more coolant this time.
I`never expected this to happen to a vehicle of this size and build, it should not happen.
just wondering what peoples opinions are.I`ll try it again but if the surf even hints at spitting outs its dummy again,then it`s goodbye surf hello landcruiser.
cheers
jack
cheers
jack
