The back of the mirror just clips on. It can be removed easily enough with the assistance of a flat headed screwdriver. After that there are a few screws that hold it onto the body. When you've finished removing it there will be a couple of holes in the wing that you'll need to find a way of filling in.
if it's a 3rd gen then there's a square cover that pops off the base, a screw under that then it just pulls off with a bit of wiggling... (the spring clip is quite tight and will probably break)
Or you could send it to Tony and then he can play with his grinder( only trouble is he gets carried away so you might not have much surf left by the time he's finished)
