What would be the problem using filtered, used, engine oil mixed with diesel.
Only curious.
Thanks Philip
This cropped up before on the first veg-oil thread, but you'd have to do a lot of scrolling to find it, down to post#66 in fact.
Here's what I said then....
Originally posted by Morr
This is also something that crops up from time to time in the veg-oil community, the simple answer is yet it will burn in a Diesel engine (when mixed with regular Diesel) with broadly similar characteristics to Diesel. However, from an environmental viewpoint it's just as bad as pouring it down the drain!
Don’t Do It !
The waste engine oil contains heavy metals from the inside of the engine, it also contains various noxious chemicals from its original composition and as a result of its time spent in the engine. Burning this oil will release these compounds into the atmosphere, a definite no no. Also from an environmental viewpoint with regard to the carbon cycle, it’s based on fossil fuel and once its gone, its gone. Unlike the veg-oil scenario you cannot grow more of it.
Best to send it for recycling in the normal manner, please don’t burn it.
