Hi chaps, a question for the KZN130 sparkies.
No preheat. I have no glowplug warning light & the glowplug relay is not getting an energising voltage. Relay function is ok on bench test. 12V glowplug supply is reaching the relay plug. Does anyone have an ideas for checking the ECU, from what I've gathered using the 'Search' tab, the relay gets its energising voltage direct from the ECU - no fuses in circuit.
I haven't found any electrical drawings that help.
Many thanks
Many thanks
