Hi everyone new to the forum in need of some big help.
My surfs just failed test for the ABS light not performing the self check which stupidly I didn't ever notice (muppet). Now the garage has it and is trying to diagnose it but, the bulb was missing from the dash (no surprise), so bulb goes in and bridge connector flash test show just a solid light for the ABS (while the SRS light is flashing). We've got power to the relays but not from. It had trailer wiring but that's since been removed.
The N/S/F hub decided last year it wanted to travel the world leaving itself connected by the steering arm and ABS wiring but we've not even got as far as to see that fault code yet.
If anyone has experienced anything even remotely similar or even better has a decent enough wiring diagram to help us out that'd be grand.
Cheers.
Cheers.
