93 2.4l 2nd Gen fit 33's with no modifications??
  • 93 2.4l 2nd Gen fit 33's with no modifications??
    hi, my 93 surf has stock 31 10.5 15" right now and im looking to get 33's for it with the same rims is this possible without lifting the truck or making any sort of modifications ?
    To get 33's under it you will need a 2+2" lift (suspension/body) to be able to turn corners, and go over bumps without damaging the arches
    Also as 33's are generally 12" wide you will require a new set of rims that are wider, assuming you are running the stock surf rims
