I may be being a bit thick but how does this make the speedo more accurate?. I would have thought the speedo would be more accurate with standard tyres on and less accurate with bigger ones
With standard tyres on my speedo ran about 10% over. Think they may well set up the speedo for the optional 31" tyres that were a factory option.
Only drawbacks are a slight loss of acceleration due to the larger rolling circumference, speedo being a bit more accurate (now I don't even think I'm going fast) .
Hi there all,if any help 265/75/15 has a rolling circimference
of 2362mm.
31/10.5/15 has a rolling circumference of 2375mm which is a
13mm differance or just over 5inches.
If you are not sure on the accuracy of your speedo you can take
the car to a Tachometer testing station where by using the
rolling road at set speeds you can see the reading on the dail
compaired to the true speed.
Or find your local road speed inforcer? Chris
Leave a comment:
Guest replied
Originally posted by icsys
I was thinking along the same lines:
Slower acceleration,
More accurate speedo reading,
Faster speed due to larger circumference therefore better MPG.
However, the difference in diameter of the 31" to the 265x70 can't be so much that the above is noticeable can it?
The 'slight wobble' in the steering wheel is a concern... wont this cause wear on the steering linkages?
Hence the post for anyone with these tyres to give their first hand experiences.
Actually the difference in Circumference is reasonably large. The diameter is 1.4 inches larger so by working out the circumferences by 2 x PI x R it comes out that the difference in circumference is 4.3 inches which is about a 4% difference which concurs with the change in my speedo reading of 4% - 5% ( checked with a GPS).
I knew that maths at school would come in useful one of these days.
I have no wobble in my steering wheel. Any wobble could be caused by the tyres being out of shape. With a more chunky tread this is possible if one of the lugs is out of true, and it may change as you put some miles on. Teering wobble may cause extra wear on the steering and suspension components so it should be checked out. Get a tyre place to put it on the balancing machine and see if the tyre is running true.
According to Toyota (what do they know) 31" was the max.
As you will no doubt find from other posts, side steps, mud flaps, etc. get in the way when you go over 31".
Also something about rubbing inside the front arch as well, so offset needs to be smaller (or something like that)...
I replaced the Bullet's 265/70/15 road tyres with 31x10.50x15 BFG All Terrains, and I didnt have any issues at all. MPG and speed were not impacted at all, and there was definately no "wobble". There was not even any noticeable change in road noise.
On our grey surf we went from 235's to 31" and there was definately an impact in terms of the power needed to reach the same speed, and in terms of the speedo. Again though - no "wobble"
What are the drawbacks of fitting 31 x 10.5 x 15 as opposed to 265 x 70 x 15
I believe the 31" tyres are slightly bigger in diameter than the 265x70
i was speeking to a work mate and she has a landi 90 and put bigger tyres on it. she reckons she can go faster due to the greater circumfrance with the same power. is this true.....might it contrabute to better mpg.....?
Leave a comment:
Guest replied
Only drawbacks are a slight loss of acceleration due to the larger rolling circumference, speedo being a bit more accurate (now I don't even think I'm going fast) and more difficulty getting the mother in law in the back (especially since I removed the side steps.
Road noise is a little more but I've got M/Ts on mine.
The only thing I have found with fitting these is a little wobble in the Steering Wheel due to the tread being AT (all-terain) on the rims and hence the gap between the ridges is more so just alittle wobble.
The measurement equates to the Width x Aspect Ratio (percentage of the tyre wall x 15 diameter)
Leave a comment:
