i suposse its been said before but can you fit 33x12.5x15 to std wheels (offset 8) to a wide body with spacers with out a lift of any kind, my 31'' bfg's are well clear of any body work as they are. 33's are only 1" greater in diameter are they not????
sizes
i cannt see why a 4" lift is needed from looking at mine theres lots of clearance all around my 31'sOriginally posted by BUSHWHACKERSee here John.....http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=20824Surf.gone but not forgotten
disco now gone aswell
cheers vince this wine is having an effect................Originally posted by BUSHWHACKER33s will be wider and taller so may rub when turning and/or going over bumps without enough clearance (lift)
i thought somebopdy on here mite of shelled out for 33's and not done his suspension lift and getts away with it.
changing subject andf going back to L.E.D.s i am thinking of setting a cluster of them in the rear bumper as a fog light and a row in the running boards what do you thinks, sons has bought me a set of neons aswell 4 for underneath and 2 for under the dash, (relucktant to fit). and wifey has got me 4 more spots.Surf.gone but not forgotten
Fit all the LEDs and the spots, then shop around for a set of air horns that sound like this......http://www.neowin.net/forum/index.ph...post&id=146035
Originally posted by BUSHWHACKERFit all the LEDs and the spots, then shop around for a set of air horns that sound like this......http://www.neowin.net/forum/index.ph...post&id=146035
Heh heh!!! What are your LED's like, Vince? I've only seen pics of the front ones, as far as I remember..?It just does, OK?
Vince have you tried those headlight bulbs made of leds??? i was looking at them in halfords the other nite, i'm using leds in the side lights at the mo they give a good effectOriginally posted by BUSHWHACKERHaven't done anymore yet, but I am thinking about fitting some ultra bright white LEDs into the rear vents on the side of the rear side windows, for high level reversing lights.
Oh, I did fit six of the bright LEDs into my centre interior light the other week.Surf.gone but not forgotten
i guess led h/bulbs would be as effective as candles,Originally posted by BUSHWHACKERHeadlight bulbs?? Haven't seen those, I've seen the rear LED bulbs though.
I have........err........illegal bulbs in my headlights anyway. 80/100w.....shhhhh!
mine is awaiting some good weather so i can tacle a wiring upgrade for the h/lamps and spots.Surf.gone but not forgotten
