tyre size?
  • tyre size?
    what are the largest size tyres i am able to run on my stock chrome 15 inch rims? not sure but i think they are 7 inchs wide? im also going to fit 2 inch raised springs, but im not expecting them to give me much more height.
    31x10.5/R15
      thanks for that tony. you sure i cant go bigger
        Not without the front rubbing on full lock, needs 2"+ lift to go any bigger, you shouldn't really put wider than a 32x11.5 on the 7" rims, but they will still probably rub without some lift, especially if they are on wider rims than 7"
