the title says it all please help?
33" BFG's what PSI should they be??
Experimentation is the name of the game. Play about till you find what suits you.Originally posted by surfstarthe title says it all please help?
I had been using 34psi in my original 31" tyres, on changing to the 33" BFG's (AT's) I figured with the stiffer sidewall and larger size a lower pressure would do.
Following some balance issues with mine (I've got fishing weights in em) I've been playing about again and am at around 34psi again. My balance issues have all but disappeared and the ride feels better.
I'm going to continue to play around a bit with the pressures once I get an accurate gauge, but at the moment, on my truck anyway, 34psi seems good.Maurice
Thanks Maurice sounds goodOriginally posted by MorrExperimentation is the name of the game. Play about till you find what suits you.
I'm going to continue to play around a bit with the pressures once I get an accurate gauge, but at the moment, on my truck anyway, 34psi seems good.Kite Surf
