wheels, PCD & offsets?
  • wheels, PCD & offsets?
    Just for my clarity what is the PCD & offset normally used by the surfs & are they the same as all/earlier hilux's etc?
    Si
    [IMG]http://img.photobucket.com/albums/v44/scooby_si/Scooby_siSig.jpg[/IMG]
    dont know what pcd is. but the offset is 8 i'm sure.
    cheers scotty
      The PCD is 6/139.
      The offset will depend on whether it's a wide or narrow body Surf..
      It just does, OK?
        IFS trucks generally use -8 for 7" rims, Solid axle pickup trucks use -20mm.
        -20mm offset 7" rims and 31" tyres fit nice on wide body IFS trucks, non-arch equiped trucks will poke out a little.
          Originally posted by TonyN
          IFS trucks generally use -7 for 7" rims, Solid axle pickup trucks use -20mm.
          Here Here....even though running IFS...when purchasing the Colway AT's running on the above info was used [but the vehicle is Wide body]. The wheels stick out by 1 inch [sorry approx 2.54 cm for those using metric].
          Gaz
            And in English please anyone?
            Will the Comet Alloys in the 4 x 4 accessories and tyres catalogue fit my 1993 2.4? without rubbing on full lock etc.
            I want to get some cos my standard wheels are shot.
            French fishing at it's best www.mayennefishing.com
              mine runs on std wheels and they have an offset of 8 hope this helps
              john
                they'll tell you when you order... i had trouble getting a set of 33" tyres sent cos they said they wouldn't fit my car!
                  Prett ymuch any 6 stud wheel will fit, but it's the tyre size that will determine whether it rubs or not. Is your truck standard?
                  It just does, OK?
                    If they are 7" wide and -8mm offset (for a IFS Hilux pickup) then they are exactly the same.
                    Solid axle pickup wheels are -20mm offset, but will still go under the arches OK as long as they are 7" wide still and look a little nicer. They don't rub normally, but get close in offroad situations with 31's that actually measure 31" (most don't.)
                      Thanks guys, a great help and much appreciated.
                      Paul.
