Andy try www.interparcel.com as these are who i use to ship overseas and i have found to be very good
Two 2nd Generation Bull Bars & A mechanical Injector Pump
Cheers Richard, I'll dig my scales out and weigh it!Originally posted by stormforce View PostAndy try www.interparcel.com as these are who i use to ship overseas and i have found to be very goodDo you know that, with a 50 character limit, it's
What year engine is the pump off of? Is it in good working order? I've used interparcel before, they're fast. ThanksOriginally posted by Albannach View PostThe pump is still available and I can ship it to you. Will check the postage and let you know the total cost.
Do you need any more info on it?
I've no idea what it came off! It has been bench tested by a local Pump specialist, he says it is fine. It's not been calibrated. If you're still interested, it'll be £250 delivered.Originally posted by Larson View PostWhat year engine is the pump off of? Is it in good working order? I've used interparcel before, they're fast. ThanksDo you know that, with a 50 character limit, it's
Thanks for the numbers. From what I gathered it has some kind of engine immobilization system integrated into the throttle/governor linkage. Are you able to move the throttle lever by hand and does it look like it can connect up to a throttle linkage? I don't know how the engine immobilizer works. Also do you have the linkage bits between the throttle cable and the pump? ThanksOriginally posted by Albannach View PostPart number is 22100-5B860
Other numbers are:
VE4/10F2100RND254
19600-2540 7
09U00220 3
