General servicing info for quick reference.
If you see anything you think should be included on this page, PM me the link to the item, or just type it in a reply on this thread and I'll add it to the post. I'll delete replys once they are in the main post to keep things tidy.
Feel free to point out any errors, wecan get them sorted out and try to cut down on some of the conflicting info.
Nothing to complicated or technical, just the stuff the 'average Joe' (or Joanna ;-) ) should be able to check and sort out, and we won't lose the info as it gets old as is dropped from the server.
Cheers.
Tony
DRIVE TRAIN
Standard rear diffs GL5, SAE 90 for above 18 deg C or 80W or 80W-90 for below 18 deg C. 2.2 Liters
LSD rear diffs just use specific LSD gear oil.
Front diffs without ADD (not Surfs) are same as rear diffs above. 1.6 Liters
Front diffs with ADD (all 2nd gen Surfs) are GL5 SAE 75W-90. 1.86 Liters
Planetary T/case (Automatic and most manual Surfs) needs GL4 or 5 SAE 75W-90 1.1 Liters
Reduction gear T/case (MK1 Surfs, and manual 4Runners) as above but 1.6 liters.
Manual Gearbox......3.0L Multipurpose Gear oil API GL-4 or GL-5, SAE 75W-90
Automatic Gearbox......Up to 4.5L Dexron II ATF fluid.
Wheel bearings....Lithium base wheel bearing grease NLGI No.2
Propshafts....
Spiders and slide yokes..Lithium base chassis grease NLGI No.2
Double cardan joint......Molydbenum-disulfide lithium base chassis grease NLGI No.2
Ball joints......Molydbenum-disulfide lithium base chassis grease NLGI No.1 or No.2
Front drive shaft drive bushings....
End float 0.075mmm and 0.69mm with a maximum of 1.0mm.
There are two washer thicknesses, one is 1.8mmm and the other 2.25mm. If more than 1.0mm end float and using a 1.8mm thick washer, change to the 2.25mm washer. If more than 1.0mm end float and using the 2.25mm thick washer, bushes are worn and need replacing.
Part Numbers. 90560-27010, 1.8mm. 90560-27005, 2mm and 90560-27011, 2.25mm.
Thanks to Nev
Clutch fluid...SAE J1703 or FMVSS No.116 DOT 3
Anti Roll bar
Stabilizer Bush, part No Y48815-20200 ..£6.06ea
Stab. Bush Bracket, part No Y48823-35060 ..£7.64ea
BRAKES
Minimum pedal floor clearance when depressed...60mm
Pedal freeplay.....3-6mm
Parking brake adjustment.....13-19 clicks
Brake fluid...SAE J1703 or FMVSS No.116 DOT 3
LN130 (bought for 1990 truck)Genuine Toyota pads, Part No.04465-YZZAF (Fit Hilux 8/88-current, LC70 1/90-current.
KZN185 (bought for 1996 truck) Genuine Toyota pads, Part No. 04465 35280 by Rob
STEERING
Wheel free play....>30mm
Power Steering fluid..... ATF fluid Dextron-II.
TYRES
265/70 R15 110S....
Front 29psi, rear 29psi Loaded or unloaded
215 R15 100S....
Front 28psi, rear 33psi Loaded or unloaded
ENGINE
3VZ-E
Engine oil.........4.2L (4.5 inc filter)
1KZ-T
Engine oil.........7L (8L inc filter)
A102 Oil Filter Toyota Part No. T90915-30002 (By Mart)
2L-T
Engine oil.........5.8L (6.8 inc filter)
Oil Grade.
Petrol.....
API SG or SH multigrade, or ILSAC multigrade.
Recommended viscosity....
Diesel.....
API CD or better
Filter Cross Referance Numbers Thanks to MattF
Oil Filters (all diesels)....
Toyota 90915-30002
Fram PH5123
Fiaam FT5429
Tecnocar RD1216
Unipart GFE328
Mahle OC275
Purflux LS895
Mann WP928/80
Fuel Filters (all diesels)....
Toyota
Unipart GFE5316
Mann WK828
Mahle KC83
Fram P4922
Fiaam FP5091
Air Filters...
2.4TD...
Mahle LX606
Mann C20189
Fram CA3688
Fiaam FL6806
3.0TD (2nd Gen KZN130)...
TBA
3.0TD (3rd Gen KZN185)...
Toyota 17801-67030
V-Belts Thanks to Tony Goodwin
3.0TD 3rd Gen KZN185....
Fan/Alt belt 90916-02385 x2
aircon belt 90916-02397
Fault Codes
To get the basic diagnostic codes, find the grey box marked Diagnostics, and join connections TE1 and E1 together. Then turn the ignition on and count the flashes of the check light.
2 figure codes have a small gap between flashes, longer gaps between individual codes, continuous flashes means all clear.
Pull the ECD fuse for 10 sec or so to clear old codes.
Diagnostic fault codes for the 2LTE diesel engine.
1 - Normal
2 - Turbo boost pressure sensor
4 - Coolant temperature sensor
5 - Correction resistance (Pump)
6 - Pump speed sensor (Pump)
7 - Throttle position sensor
8 - Intake air temperature sensor
9 - Vehicle speed sensor
10 - Starter switch
11 - Switch sign (Vehicle not in P or N or A/C on)
12 - Timer control valve (Pump)
13 - Crank position sensor
1KZ/TE codes....
Vacuum pump rotors......Toyota Part 29331-56070 and cost £13.15 +VAT each.
'89-'91 cars use four and the '91-'94 cars with the later type of alternator use three. thanks to Elvie
RPM sensor o-ring...
http://www.hiluxsurf.co.uk/showpost....56&postcount=6
Starter Motor.....
Contacts
Allthe parts can be obtained from Toyota.
http://www.afm15.dial.pipex.com/sur...eplacements.pdf
All the starter bits are listed here;
Plunger, Magnet Switch (Solenoid) Part No. 28235-17030- £14.92
Fits 2LTE, 3L..LN13# IKZTE, 2L#, KZN130, LN108,112,85..4FC
Starter Kit, Motor Terminal (The bit the plunger hits and connects the starter motor) Part No. 28226-54220 £9.39
Starter Kit, Battery Terminal (The other bit the plunger hits) Part No. 28226-54320 £5.78
thanks to Fieldsy
Cooling........
1KZ/TE 71*C thermostat 90916-03121
Coolant...
3VZ-E.....10L (9.8 with Auto)
2L-T......9.1L
1KZ-T.....10L
Type......Ethylene-glycol antifeeze/anticorrosive
Thermostat (91' 2.4)..... 88 degree (Toyota part no 16340 54010) thanks to JimL
Cap (91' 2.4)..... 0.9 bar (Toyotoa part no 16401 63010) thanks to JimL
2LT/E Electric fan temp sender......
Toyota part number T83420-20020 thanks to Kitesurf Phil
Filling cooling system........
With all the heaters on, fill it via the hose that does a 180 deg bend into the heater control valve with a watering can, fill till coolant comes out rad, put cap on, keep filling till coolant comes out of heater control valve and pop pipe back on.
Take it for a run and check it at the rad cap when cold or next morning and it shouldn't need much more water.
Cylinder Head............
2.4 2LT/E... thanks to Koi
1st stage 58ft/lb 78nm
2nd stage 90 degree turn
3rd stage 90 degree turn.
Undoing Crank Pulley bolt.....
http://www.hiluxsurf.co.uk/showpost....8&postcount=19
2L/T Vacuum hoses......
Rear window..........
Relays are avalable from
Omron Electronic Components Europe
Sub-Miniature Automotive PCB Relay
G8SN-1C7-CUK 12DC (320oms) spdt motor,resistive.
Or from Maplins
JM67X 12V/12A Min relay Thanks to Tom Lilley
Rear Wiper Blade........
Screw on type, Genuine Toyota, pt no 85220-22461 (350mm)
Cheers.
Tony
DRIVE TRAIN
Propshafts....
Thanks to Nev
Anti Roll bar
BRAKES
STEERING
TYRES
265/70 R15 110S....
215 R15 100S....
ENGINE
3VZ-E
1KZ-T
2L-T
Oil Grade.
Petrol.....
Diesel.....
API CD or better
Toyota 90915-30002
Fram PH5123
Fiaam FT5429
Tecnocar RD1216
Unipart GFE328
Mahle OC275
Purflux LS895
Mann WP928/80
Toyota
Unipart GFE5316
Mann WK828
Mahle KC83
Fram P4922
Fiaam FP5091
Air Filters...
2.4TD...
Mahle LX606
Mann C20189
Fram CA3688
Fiaam FL6806
TBA
Toyota 17801-67030
Fault Codes
1 - Normal
10 - Starter switch
1KZ/TE codes....
Starter Motor.....
Contacts
thanks to Fieldsy
Cooling........
Coolant...
2L-T......9.1L
1KZ-T.....10L
Or from Maplins
