RIGHT! for anybody who is thinking about doing a suspension lift or a body lift to their surf then this is the thread with all your answers!
First up is the SUSPENSION lift.
There are a few ways of doing this.........
1: The Cheapest Way:
The cheapest way to lift your surf is by fitting 2" spring spacers on the rear and raise the front torsion bars 2". not the best way as on road ride qulaity will suffer a lot. (not a comfy ride) This one is purely for looks.
2: The Second Cheapest Way:
The other cheap option is using what we call on here as the LANDCRUISER WAY aka LC way/setup.
this is when you take Landcruiser springs (REAR ONLY!) from a HDJ80 Landcruiser (LC for short) and fit it to the rear of your surf. you can get the springs at a cost. of £55 for the pair at Milners Offroad. here is the link http://www.milneroffroad.com/categor...?cID=11455&p=2
if you are planning on doing the work yourself, the LC springs are VERY stiff so may have to drop the axel to fit insted of using spring compressors. shame, but oh well
The LC springs will give you about a 3" lift on the rear. not bad for about £55!!!
you will however need to buy either +2" or +3" shocks to go with them. NOT the LC shocks!
3: A More Expensive Way:
basically the same but buying specific lift kits. they vary from around £275 - £500 for a 2" suspension lift kit.
Benifits from these are they will have the neccesary brackets etc etc etc(saves you making them).
Right, things you need to know when raising the rear this way. fitting instructions if you like?
1: unclip the brake lines. (before you start! lol)
2: unclip the LSV. (load sensor valve. this valve sends more power to the rear break drums when weight is incread in the back due to load or passengers)Make sure you unclip the pipe from above as so you dont muller it! Then see if there is enough play with the new springs on AND with the axel at its lowest point! (truck jacked up and axel hanging will show you this)
if not then try rotating it 180 degrees. or totally unclip it and fab up a new bracket to fix it back down.
3: remove the ARB's. (anti-roll bars aka sway bars) As the LC springs are much stiffer than the surf springs you can get away with removing the ARB's completely without noticing any body roll around corners.
it is not recomended to completely remove the ARB's when installing aftermarket +2" springs. (LC's are ok) You can either extend the ARB's (aka sway bars) with longer bolts or droping the bracket somehow. (either buy specific sway bar disconect's from 4crawler.com or fab up a bracket)
4: if this lift is only for cosmetic's and will not be seeing any (or hardly any) offroad use then you shouldnt need to extend your break lines. there should be enough ply on them to just fit back onwithout too much fuss. if you are going offoading then buy extended break lines!! you can get them from roughtrax. here is the link. http://www.roughtrax4x4.com/index.php?doc=87
IMO worth doing regardless. they do not cost much and you will only benifit.
5: With the LC springs, as they are a larger diamiter than the surf springs, you WILL NEED an Alloy Seat for them to fit snuggly into. otherwise your springs can slide out! (not good!)
i bought mine from here for about £130 inc. delivery. http://www.outrageousoffroad.co.uk/
here is a pic of what they look like fitted: (thank you POPEYE!)
See POPEYES write up with pics for more info on fitting LC springs:
Originally posted by POPEYE
View Post
