Well I got up bright & early & fiited an L200 intercooler to my 2.4 Surf.
I decided to fit it on the side so that I could use a side scoop (L200).
I removed the airbox, boost pipe etc. Fitted the intercooler using some brackets to the wing mounts. I had some pipes with the IC which, with the cunning use of a hacksaw I could re use, along with some lengths of exhaust pipe (45mm) & some reducers. All I needed to buy was the IC, reducers, a couple of jubilee clips, a fandango air filter and some pipe for the breather.
The only downside so far is the noise from said air filter. I think I will run a pipe across the engine bay & mount it under the IC, which I hope will take the edge off the racket !
Ive drilled the bonnet ready to cut the hole out but I bought the wrong jigsaw blades, so will do that tomorrow, Oh & buy a scoop !
Will post more pics when finished.
And all this without a body lift
Apologies for the size of pics but I left my camera on the higher setting, so I cant download using the software here
Steve
Steve
