Hi There Can Anybody Help Me Im Goin Out Of My Mind, Ive Had The Check Light Come On And Sent Her In To The Auto Electrician And Cost Me £180 To Say They Dont Know Whats Wrong, So I Searched The Net And Found How To Read And Check The Obd Codes And Found That It Is The Engine Temperature Coolant Sensor, But I Dont Know Where Or Which One It Is, My Surf Is A 1992 Ln130 2.4td, Can Anyone Help Please!!!!!!!!!
Nope. Wrong one. That's for the Temp Gauge. This is the one that supplies info to the ECU and give the fault code.Originally posted by BUSHWHACKERHere is a pic of the thermostat, the temperature sender is the one circled in yellow.
p.s. £180??????????????
Read this link off the Oz surf website - it seems to describe the problem you're havingOriginally posted by fattmanhi, thanks guys ill give it a go, thanks alot
http://www.toyotasurf.asn.au/techsite/turbovacuum.htm
Check out some of the other tech links - they may help
regardsAnother member of the 'A' team
Genuine Toyota only as far as I know. Before you run out and buy one check the wiring and connectors on the sensor. May be just a loose plug or dirty terminals.If you do fix anything don't forget to clear the fault codes after.Originally posted by fattmanhi chaps does anyone know where to get the engine coolant temperature sensor from and how much ,many thanks Nigel
I've got a second hand one if they turn out to be hideously expensive from Toyota.Originally posted by fattmanhi chaps does anyone know where to get the engine coolant temperature sensor from and how much ,many thanks Nigel
