URGENT new head fitting injectors
  • URGENT new head fitting injectors
    Hi folks I'm just building my new amc head and just on the injectors now in the gasket set from rough trax there is a set of 4 gold coloured washers with black rubber type seal fitted to them where do these go? I'm wondering if they go below the injector top hats as I don't want to fit them to find out I've missed something. Would add pics but I'm down the garage at the month
    Marty
    here is the little buggers i mean just cant place them is it injector seat at the bottom then crush washer then the injector or is there something below the injector seat like these?
      there not injector washers , do they come from a full gasket set or a head set? the rubber part is some sort of oil seal
      JAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
        if yours is a 3.0 they have something like those on the inlet manifold
          they came with the head gasket set
            They are new washers for the cam belt cover bolts.
            Injectors just get the tiny alloy crush washers.
              ah sweet so it is injector seat then crush washer then injector
              on the crush washers i have 8 in the gasket set why is this?
